Obtaining References of Controls Inside of Tab Controls
Does anyone else have the same luck as me, where you scratch you head for a good part of the week then it all comes together in the last hour of the week on Friday? This seems to work quite well.
Message 11 of 14
(933 Views)
By the way, thanks Ben64 for your help. It was much appreciated.
--Brian
Message 12 of 14
(931 Views)
well..sometimes things seem perfect that they are just a bit off. Here is where I am now.
With the code below, the 0th conrol coming out of the panel property node is the tab control that I want to access.  Can I use some NI vi to select the 0th item in the array from "controls[]" and wire it to the input of the Pages on the Tab Control?
Message 13 of 14
(917 Views)
Use the index array vi and wire 0 to the index input. You will get the reference to the Tab Control to use with the property node. Note, the pages property is read only and return the page collection of the tab control.
Ben64
Message 14 of 14
(910 Views)
