Ocean Optics NIRQUEST spectrometer
Hi guys,
I am writing this topic because I have some problem with my spectrometer (Ocean Optics NIRQUEST) and LabView (I am using the 2018 32-bit version in a 64-bit Windows system).
I have to build an experimental setup and I should control everything through LabView.
What I have to do is to acquire the signal of a laser through the spectrometer and I would like to analyze it directly in LabView.
The problem is that I don’t know how to connect the spectrometer to LabView.
As you can see, in the program that I have written I would like to connect the spectrometer in the flat sequence after the part dedicated to the creation of the file .csv.
Could you help me?
Thank you.
(3,547 Views)
Accepted by ercallo
(3,522 Views)
Thak you so much.
I have just installed the drivers and now I can use the spectrometer through LabView.
I just have to understand how to set the parameters to obtain the right results.
(3,502 Views)
