Ocean Optics Omnidrivers package
Thanks a lot for this extensive description.
greetings from the Netherlands
Message 71 of 79
(2,367 Views)
Thank you a lot Joe!
I run LV8.6_SetAcquisitionParameters_NET.vi and it works great except that when I stop the VI it gives me an attached error at the "Close reference"
Do you know the reason for that?Have I installed anything wrong?
Thank you again! I see a hope that my project will work 🙂
Anton.
Message 72 of 79
(2,323 Views)
I can't really tell, but does everything else work? Can you aquire spectra? Could you post your vi? Or is it just one of the ones that me or ocean optics provided. I am on the phone right now so I can't check that...
Message 73 of 79
(2,298 Views)
Everything else does work (spectra are aquired), but when I press "stop" it spits up the error message.
The VI is from the package, unmodified. I am using Labview 11 to open it.
Message 74 of 79
(2,291 Views)
I'll have a look as soon as I am back but if you acquire spectra, I don't think you installed something wrong.
Message 75 of 79
(2,283 Views)
Hey There,
I can't really check what is going wrong since I don't have LV2011 and I also have no longer acess to the Spectrometer. I opened the "LV12_SetAcquisitionParameters_NET.vi" and saved it for LV2011. Since the 2011 is much closer to the 2012 that 8.6 this might help. If not I can't really help you right now, sorry.
Regs,
Joe
Message 76 of 79
(2,271 Views)
have you reslove this problem?
Message 77 of 79
(2,138 Views)
Hello there, i have just purchased the latest version of Omnidriver+SPAM (2.37). i have succesfully run the SetAcquisitionParameters_NET.vi in normal scope thanks from u guys. However, i have difficulties running it with SPAM in Labview 2011. Plus the are no such documentation that would help. Anyone have good knowledge using SPAM in Labview especially with Absorbance mode. I hope someone can share it with me. The picture of the interface is attaced.
Message 78 of 79
(1,986 Views)
Why don't you use the driver that is in the NI drivers page?
You cannnot use this next to the ocean optics package but is completely written in labview
Message 79 of 79
(1,972 Views)
