Odd myRIO PWM problem
Hi. I have an odd problem with my PWM duty cycle. At 1 = 100% duty cycle I have no power and full power at 0 = 0% duty cycle. How can that be???
Kind regards
Lasse
Message 1 of 9
(3,286 Views)
Hi Lasse,
I guess the problem is within your VI. You just need to find and remove it!
Btw. which answer do you expect when providing so little information?
Message 2 of 9
(3,275 Views)
I've already tried the basic PWM express VI. Same thing??? Also on another myRIO. It makes no sense to me??
Message 3 of 9
(3,258 Views)
Hi Thorfinn,
unfortunately I'm stuck at LV2017 right now, so cannot open your VI.
Well, it makes sense to me - for a certain kind of DAQ hardware!
I'm using PWM generating devices in my testbenches (like this). Those PWM modules use "low-side" switches ("open-collector" outputs, switching to COMMON/GND). Because of that I need to use pull-up resistors and handle an inversion of the output signal: 100%PWM signal leads to 100% switched to GND level leads to 0% power at the connected device…
So your observation can make sense - it all depends on the used hardware!
Message 4 of 9
(3,253 Views)
Hmmm... Makes sense if that's the case. But I'm using the Digilent motor adaptor for NI myRIO and a LEGO DC motor which actually states that the A4973 driver used has been configured for a 1.5A max current at 100% duty cycle. Then again I must be missing something here because your explanation makes perfect sense. Thanks!
Message 5 of 9
(3,246 Views)
What does the signal look like at 25% and 75%.  Does .25 look like 75% power, and .75 look like 25% power?
Message 6 of 9
(3,242 Views)
Sorry for the late reply.
Yes .25 gives a 75% high signal...
Message 7 of 9
(3,232 Views)
Hi Thorfinn,
some DAQmx devices also allow for logical negation of digital output signals - maybe you incidently enabled a similar feature on your myRIO?
Message 8 of 9
(3,230 Views)
I can't find that option anywhere and I'v also tried on two separate myRIOs. The funny thing is that I didn't had the same problem with Labview 2016 a couple of years ago... For now I'll just negate and add one to correct it. But thanks Smiley Happy
Message 9 of 9
(3,227 Views)
