sending Data to server
I have created a Vi and now i want to publish that data  to server which i acquired from the sensors. to the server. So, that i can use that value to control a device using IOT technology. How can i do this?
(2,339 Views)
Hi Supravat,
How can i do this?
  1. Use the protocol supported by the server and your "IoT technology".
  2. Connect with the server and publish your sensor data…
In case you need more specific answers you should provide more information on your (LabVIEW) problem!
(2,316 Views)
