Offset value of Simultaneous analog input NI 9683 GPIC
I want to take the voltage/current sensor signals from the simultaneous analog input of NI 9683 GPIC board. In most of the examples it is given that to get the actual signal, the offset value is subtracted from the output of the GPIC board and the resultant is multiplied with the sensor gain. I could not find how to select the offset value. In both the attached model scaling is taken different.
(2,510 Views)
I am also having same issue of how to convert this raw data into meanigful data. any help please?
(2,210 Views)
