Old VI, new LabView and DAQmx Driver
I was given a VI that was made with LabView 2012 and DAQmx drivers 7.0. I am in LabView 2013. Would this VI still work if I installed new drivers (drivers that are compatible with LabView 2013)? Do I have to install LabView 2012 or can I just install new drivers?
(3,058 Views)
Accepted by TimCast
DAQmx 7.0 was not compatible with LabVIEW 2012.  In fact, it was barely compatible with 8.1.  Perhaps you meant 9.7?
Just use the new drivers and save the VI(s) in LabVIEW 2013.  You shouldn't have any issues.
(3,048 Views)
Thank you, and yes I meant 9.7. I'm going to install 9.8 now and save the VI in 2013.
(3,018 Views)
