Old serial vi works but serial example using VISA has to have error handleing removed
Old serial vi works but "Basic Serial Write and Read ", example using VISA has to have error handleing removed "write Bytes to port"or throws:
Error -1073807298 occurred at VISA Write in Basic Serial Write and Read.vi, VISA:  (Hex 0xBFFF003E) Could not perform operation because of I/O error.
I read through some of the threads and tried removing and adding the drivers and this did not fix the issue.
Any suggestions would be appriciated, I'm using LV8.6.
-SS
Message 1 of 11
(3,389 Views)
Just a guess, but are you trying to talk to a port that is bring used by something else? Does it behave the same way on all serial ports?
Mike...
PS: No problem on LV2012 (win7)
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(3,378 Views)
No the ports are freed up and yes it behaves the same way on both ports.
They are virtual USB to UART ports.  -SS
Message 3 of 11
(3,359 Views)
Does your computer have any built-in serial IO? Do the drivers work with them? Can you access the serial dongles from other programs like hyperterminal? What OS are you using? Who makes the dongles that you are using?
Mike...
LabVIEW Champion
Message 4 of 11
(3,339 Views)
Mike...
Yes, one built in serial I/O. No, since I am using a USB connection for my hardware that is required. Yes, Tera Term and Hyperterminal work.  The OS is Windows 7 (officially not suported I think).  USB drivers are made by Siliconlabs.
I will install LV(latest) on a 30 eval and see if it has the same issue.
I know VISA works fine on other hardware, I'm just trying to make sure I don't have a hardware problem lurking under the hood of my driver.
Message 5 of 11
(3,333 Views)
Based on what your answers, I think I would lean towards a compatibility problem between Win7 and the older version of LV. I have used SiliconLabs products in the past and in my experience they were always solid.
MIke...
LabVIEW Champion
Message 6 of 11
(3,330 Views)
Update...same error occurs on LabVIEW 2012 with all patches. -SS
Message 7 of 11
(3,308 Views)
Hmmm... Well so much for experience. Do you have a dongle made by a different vendor available?
Mike...
LabVIEW Champion
Message 8 of 11
(3,304 Views)
How do you determine at runtime which VISA driver is being used?  I would like to know which VISA driver the "VISA Write Function" is using the LV8.6 version or the LV2012 version.
Message 9 of 11
(3,296 Views)
There should only be only one set of VISA drivers on the PC. You can see what is installed in MAX, under software. Are you running VISA 5.2? There is another question active right now with a guy who is using VISA 5.2 and is also seeing strange write errors communicating with a USB dongle. Here
Mike...
LabVIEW Champion
Message 10 of 11
(3,294 Views)
