11-06-2007 05:15 AM
11-06-2007 06:13 AM
11-06-2007 06:21 AM
Hi Ton,
thanks for the Idea but ofcourse i don't open the file every access. the file remains open after an initial access and is read sequentially.
There is no file positioning before the read because the file position is maintained after the read.
There is also no general timing issue, as i wrote:
- from local system system the access time is 0.14ms per line which results in an amount of 1 minute per 10 MByte of data.
- from DFS file system there is a spread between 0.16ms per line which is a good performance
up to 9 ms per line and more which leads in an amount of 30 Minutes and more for 10 MByte.
Thanks for the answer, Hacky
11-06-2007 06:28 AM
11-07-2007 02:42 AM
11-07-2007 02:49 AM
Thank you Ton,
thats what i know as workaround for thr time beeing.
Best regards, Hacky
