save a waveform in a txt file
Hello, I just want to save my waveform into a txt file in the format: Time(s)[tabulation]Current(A). My waveform data is retrieved from a DC Source with triggered options and give me the Y values corresponding to my current measurements. The values are stored in a buffers with 4096(or less) samples with a variable sampling interval from 15.6us up to 1second. I just need to convert the samples in time and store the wavaform in a txt file.
Any help ? thanks...Labview 8.5 winXP
(3,291 Views)
Please keep to your original thread, otherwise the information gets scattered and the forum poluted.
André (CLA, CLED)
(3,278 Views)
You will have to start to learn to program in LV yourself. Using the functions in the File I/O palette and the String palette. See LV examples.
André (CLA, CLED)
(3,274 Views)
Thanks and sorry I'm a bit confusedSmiley Sad
(3,272 Views)
In order to save your waveform data you can use the function : Get Waveform Components.
You can also take a look at the example right here : http://zone.ni.com/devzone/cda/epd/p/id/164.
Kind regards,
Message Edité par Maxime MULLER le 11-07-2007 03:07 AM
(3,245 Views)
