On string controls, "update while typing" is not working with '/' (slash) code display?
I am using LabVIEW 8.5.  If "Update while typing" is turned on, then the string display is forced to "normal" display.  How can I configure the string to display '/' codes (slash codes) and have the "update while typing" enabled?
Ganesh
Message 1 of 9
(3,621 Views)
right click the string control or indicator and go to '/' codes display
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 9
(3,618 Views)
Right-clicking and selecting Update while typing disables the /code display mode.  I am looking for ways to have both turned on.
Message 3 of 9
(3,615 Views)
That request
Ganesh
is not very well defined. Say I wanted to specify the space character which (I think is "\20") and I enter "\2" but have not enter the "0", how would LV know I was thinking about the space and not another character?
Just thinking out loud,
Ben
Message 4 of 9
(3,614 Views)
Ben,
Space character is \s in slash code and x20 in hex.  I would think that when the string control is in slash codes mode and whenever a \ is entered, LabVIEW or the user software should expect a character following it (for eg: \r, \n, \t, \s etc).  If someone wants to enter a \ character then he should enter \\.
This is what I expected LabVIEW to do.
Ganesh
Message 5 of 9
(3,608 Views)
But aren't there non-printable characters (yes space was a bad example) like EOT STX that must be entered as "\00" or "\02"?
Ignore me if I'm wrong.
I would think that we would have to use a normal control and do some coding to turn the slash codes into there equivelent strings.
Ben
Message 6 of 9
(3,604 Views)
You are right....I see the problem now.
I will try to work around it.
Thanks.
Message 7 of 9
(3,591 Views)
Ben,
What LV functions can I use to programmatically convert strings from slash code to normal and vice versa.  For eg:  I am reading a test script which as \r in the text.  I am passing this command string to LV VISA serial write.  I want LV to interpret this as carriage return and not as 2 characters '\' and 'r'.
Ganesh
Message 8 of 9
(3,581 Views)
If I understood correctly, then you can just use the Search and Replace String function for that.
Message 9 of 9
(3,570 Views)
