niorbu.dll not found prevents NI-DAQ from running
I just installed labview 8.6 evaluation SW and I got the niorbu.dll error message. Also I can not open NI-DAQ because of this error. Any help will be appreciated.
(2,950 Views)
Hey jonR,
Did you install the DAQmx driver after installing LabVIEW?  The order of installation is important.
I would recommend to reinstall the DAQmx driver in either case, but please post back if this does not fix the problem (also post a screenshot of the error and when exactly it occurs).
Hope this helps!
Misha
(2,930 Views)
Thanks for replying. I did not install the DAQmx driver. Should this be done automatically? How would I know on my own that I need to install it ?
I did a search on "DAQmx driver" and I found the file: is_daqmx_ready.vi
Is this the driver and how do I install it?
Jon
(2,906 Views)
