One Asus Router, 2 Web Servers on 2 separate computers, how to configure?
Labview 2012, windows 7 Pro on computer A and windows 7 home on computer B.
Computer A and B are connected to the router using wifi.
IP for computer A is 192.168.1.76
IP for computer B is 192.168.1.79
Now the router is set up in a way that it publishes the webserver on computer A, i.e. when I type, 128.200.xxx.xxx:80, it directed me to the LabVIEW Web Server on computer A.
Is there a way to have the LabVIEW Web Server on computer B come into play, using the same router?
Thanks you.
-Chen
--------edit-------------
Forgot to mention that I was trying to connect from the WAN
(4,252 Views)
What does the router have to do with anything? It seems both computers are on the same LAN, so the router just acts as a dumb bridge.
You should be able to reach any LAN computer from any other LAN computer on the same subnet. If it does not work, it might be a firewall setting on the server.
Are you also trying to connect from the public network (WAN side of router)?
(4,240 Views)
Sorry I forgot to mention, I was trying from the WAN, thanks!
(4,236 Views)
Accepted by thitchen007
You simply need to run the second server on a different port.
(4,220 Views)
