One Mux, two DMMs
Is there any advantage to using two DMMs with one Mux?  I am using a PXI 2527 Mux and would set up two scan lists, one for each 4071 DMM (through com0 and com1).  I am reading DC volts on all channels and speed is not an issue (I need to run at a few Hz).  A DMM resolution of 4.5 digits is sufficient.
(2,894 Views)
Les,
I don't see any advantage two DMMs will give you if speed is not a factor.  Also, using one dmm and scanning through each connection one at a time will make the code simpler as well.
Good luck,
Brian
(2,885 Views)
