One row data file to graph
Hi.
I am new to LabView. I am using version 5.0.1. I have a text file with data like this:
0.00059
0.02154
-0.25665
0.26787
It is a single row of decimal numbers. This numbers are samples taken at a fixed sample rate (say 0.005 s). I just want to read the file and make a graph from it. I have tried using the "Read From Spreadsheet File" VI with no luck at all. Could you please help me with this? Thanks in advance for your kind help.
Carlos.
(2,681 Views)
I have used a very similar code for my application.
I attached a JPEG example.
I Hope this helps.
(2,671 Views)
Thanks a lot! That was exactly what I needed.
Carlos Marcano.
(2,646 Views)
