One shot rising digital input
Is there any way to duplicate logic in a PLC for a one shot rising in Labview?  I need to run a boolean case only one time per button press.  If the button is held the case can only execute once, the button must then be released and pressed again in order to run the case again.  I am using a 6514 digital i/o board.  Please help.
(4,179 Views)
Try the attached vi:
- tbob
Inventor of the WORM Global
(4,172 Views)
vi worked perfect!  Thank you.
(4,158 Views)
