insert into array
Question:
I have an initialized 1D array of 64 zeros. I want to load values into each row (index) as i receive them and keep the zeros.
Is this possible?
I tried using the insert into array function but it keeps on re-initializing the array.
Thanx
FredFred
(3,472 Views)
I think this is what you are looking ofr.  You need to use replace instead of insert
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,469 Views)
Thanks!
I thought replace only went for 2D arrays.
FredFred
(3,456 Views)
