One way switch basically
A blinking LED once turned on by a switch, should not be turned off after that. It must be always be on even if the user puts the switch off.
(3,804 Views)
(3,800 Views)
If it stays on, it is no longer blinking, right?
If the switch is operated, do you want it to go...
... from blinking to ON?
... from OFF to blinking?
... or something else?
Please clarify.
(3,774 Views)
He's using the Blink property so it goes from off to blinking..
(3,769 Views)
How do you know? 😮
(3,765 Views)
From his other thread...Smiley Happy
(3,738 Views)
My mistake..not the blink property, he's toggling the LED's in each iteration of his loop.
(3,727 Views)
