Only Run Continuously
Is there a way to only allow a user to run a VI (or *.exe) continuously? Or
to have a VI run continuously when called? My work around for this is to
wrap a WHILE loop around the VI's diagram. This seems sloppy to me.
(4,792 Views)
The run continously starts and stops running each time. That is sloppy behaviour. The while loop is the correct behaviour !
greetings from the Netherlands
(4,792 Views)
Albert is correct.
The continuous run button is just a convenient way re-running code.
(4,792 Views)
