Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Only Run Continuously
Peter T
Member
02-20-2001
05:00 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there a way to only allow a user to run a VI (or *.exe) continuously? Or
to have a VI run continuously when called? My work around for this is to
wrap a WHILE loop around the VI's diagram. This seems sloppy to me.
0
Kudos
Message
1
of 3
(4,780 Views)
Reply
Re: Only Run Continuously
Albert.Geven
Trusted Enthusiast
02-21-2001
02:24 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The run continously starts and stops running each time. That is sloppy behaviour. The while loop is the correct behaviour !
greetings from the Netherlands
4
Kudos
Message
2
of 3
(4,780 Views)
Reply
Ben
Knight of NI
02-22-2001
08:07 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Albert is correct.
The continuous run button is just a convenient way re-running code.
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
3
of 3
(4,780 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
