Only one Vi Debugging with LVOOP
@paul_cardinale wrote:
When I try to do that in my pop-up menu code, I always get Error 91 out of "Variant to Array".
Probing the "Value" variant, it looks good:
'TestFrame Light Settings.lvclass': TestFrame Light Settings.lvclass [LabVIEW Class]
I was able to work around that.  But now this piece of test code throws error 1106,  Why?
Message 11 of 29
(1,760 Views)
Not sure, that seems to be no problem in a VI that's in the normal context..
Message 12 of 29
(1,756 Views)
Here's my attempt.  It doesn't work, and I can't figure out how to fix it.
To try it:
  1. Figure out where LabVIEW's default data directory is
  2. Put the attached .llb in “<default data directory> \PopupMenus\edit time panel and diagram\
  3. Start (or close and restart) LabVIEW
  4. Open a VI with an LVClass object on the front panel
  5. Right-click on the object
  6. Select "Edit Object Data..."
  7. When the dialog box opens, click on "Apply Changes"
The code will pause at a breakpoint in "Execute Edit Object Data,vi".  The error occurs after that (1106 or 1527).  Notice that the code tries every possible context; they all fail.
Message 13 of 29
(1,736 Views)
There's a missing VI (Edit Object Data Presenter.vi, or something like that)...
Message 14 of 29
(1,726 Views)
When I open it, nothing is missing.
Message 15 of 29
(1,709 Views)
When I open it, Edit Object Data Presenter.vi is missing...
Message 16 of 29
(1,697 Views)
OK.  Fixed that.
Message 17 of 29
(1,687 Views)
I can't get it working either. At least not with XML.
I'm pretty sure it's something in LabVIEW preventing this.
Flattened data seems to work. I have only tried this with copy-paring data, so not with automated string manipulation. However, copy-paste flattened data works, while copy-pasting XML doesn't.
Message 18 of 29
(1,667 Views)
OK.  Do you have anything in your bag of tricks to convert flattened data between cluster and class?
Message 19 of 29
(1,654 Views)
I'll have to dig. Deep.
I'm sure OpenG has tools for that (never used them though).
IIRC, from an cluster to an array  of variants to flattened data back to the cluster isn't that hard.
I can't remember I ever had to decorate a cluster back to a class, back to a variant (if that's needed).
Message 20 of 29
(1,648 Views)
