Open DMX to control RGB LED lights
it's impossible to set baud rate at 250000.
Why???????????????????????????????????????
Message 31 of 38
(3,066 Views)
From tthe manual
The NI 9871 supports arbitrary baud rates according to the following equation:
BaudRate = 3.6864 Mbps / (Prescaler * Divider)
Prescaler can be (4..65535).
Divider can be 1 or 4
This results in a baudrate of:
3.6864 Mbps / (15 * 1) = 245.76 kBaud as the closest possible baudrate
Rolf Kalbermatter  My Blog
Message 32 of 38
(3,048 Views)
Thanks a lot for the answer.
I'm working with ni 9871 and crio 9012 in scan interface and when i set this baud rate I 'have the same error : -1073807330.
Could you help me?
Message 33 of 38
(3,009 Views)
Hello
here I am looking VI to control a projector have led
you could send an example n thank you
I have the cable usb2dmx
thank you good day
Smiley Happy
laitimix@gmail.com
Message 34 of 38
(2,942 Views)
Hello. I'm sorry for my english. Here is my working VI USB to DMX512 I used FT230XS and SN75176
Message 35 of 38
(2,601 Views)
Hi miso,
that's not a VI, but just a JPG showing a part of a block diagram of a badly written VI…
Please do those steps before posting your real VI:
- implement error handling
- show the labels of all controls in the block diagram!
- use AutoCleanup
- get rid of the (mostly) unneeded sequence structure
- get rid of InitArray functions when the size is set to just 1!
- are you sure you need to wait for 13 ms in parallel to a VISAWrite?
Message 36 of 38
(2,592 Views)
Hi Serdi,
I am try to control Enttec DMX USB PRO without any success. I did create the VI as you show in post. When I run the VI, the Enttec DMXUSBPRO get no response and VI gets no error. if DMXUSBPRO get response, the green light should blinking. I tested it with Enttect's software. I see you were able help Emann and Trintiy solved issue. Would you help me to look my VI where i did wrong?
Johnny
Message 37 of 38
(2,333 Views)
Hello, could you save The USB2DMX in LV 7, Thank you
Message 38 of 38
(1,044 Views)
