Open LabVIEW 2010 project with 2011
I'm working on a project which has been developed under LabVIEW 2010 and I just update my LabVIEW version to 2011. Nevertheless, I can't open some files with LabVIEW 2011. This include project files (.lvproj), class files (.lvclass) and some VIs.
When I try to open these files LabVIEW crashes and displays the following window :
Have you an idea of the origin of this problem ?
Thanks...
Message 1 of 13
(5,477 Views)
Are you using any XControls? Can you isolate specific VIs that are causing the issue?
Unfortunately this is not a unique problem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 13
(5,473 Views)
XControls don't seem to be used.
I can isolate some VIs : for example VIs which are used for HTTP communication can't be opened. They are all in a same class and some of these VIs are calling VIs of the "LabVIEWHTTPClient.lvlib" library of LabVIEW 2010. Maybe it could be a source of the error ?
Message 3 of 13
(5,464 Views)
Have you tried mass compliling your LabVIEW after install?
Tim
GHSP
Message 4 of 13
(5,462 Views)
No I didn't try this. What is mass compiling ?
Message 5 of 13
(5,457 Views)
Mass compling make LabVIEW go back through all of the VI's and relink or refind them so that they are corret when used. It will take a long time for this to run so start it before lunch and it should be done after. I am not telling you that this will fix everything but it should help.
Tim
GHSP
Message 6 of 13
(5,455 Views)
If you haven't done so already, please send in the crash report so NI can start to fix these issues. Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 7 of 13
(5,447 Views)
Ok thank you. I want to try this but I'm fear VIs don't work neither with 2010 nor with 2011...
Message 8 of 13
(5,445 Views)
yes I already send the crash report to help NI to fix this issue
Message 9 of 13
(5,443 Views)
In your National Instruments folder you have separate sub folders for different versions of LabVIEW.  If you open a 2011 VI and mass compile it will affect the 2011 folder so your 2010 files are safe.  If there are any weird problems that do effect LabVIEW as a whole you will probably need to re-install LabVIEW completly anyway.
Message 10 of 13
(5,421 Views)
