Open Labview version 5(older versions) in the latest labview version
Dear All,
Is it possible to open labview version 5( older versions) in the current labview 16 versions. I have a couple of files to analyze.
Have a great summer!
(3,624 Views)
Accepted by Dr_spacepirate
Unfortunatelly, it's not possible. You could post your VIs to createn new topic here, so someone can convert it.
Sincerely, kosist90
Check out new features of LabVIEW 2017!
(3,620 Views)
Thank you for your reply, kosist90
(3,614 Views)
The latest version that can open V5 seems to be 8.2, you can download it and use it to look or resave as 8.2. v8.2 should be able to open in the latest version (atleast 2015 could open it according to a matrix i saw).
Of course, getting it converted through the Conversion thread is an easier solution, but if you have several the above suggestion should work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,553 Views)
(3,518 Views)
