Open MATLAB main window from matlab node in labview
At the moment (as default), when I load a vi containing a MATLAB script node, a MATLAB command window opens.
Is it possible to do something in the setup somewhere so when a vi is loaded, instead of opening the MATLAB command window, the main MATLAB window opens?
Thanks.
Ian
(5,768 Views)
Ian,
I haven't been able to find any documentation of doing that directly.  However you could open the application itself using a system exec command if you just want to open a full Matlab application.
regards,
Pat b
(5,698 Views)
Pat,
Yes, I can. But MATLAB opened from "MATLAB script node" in LabVIEW and from "open MATLAB application directly" are two independent instances of MATLAB. They have different "workspace".
Thanks.
Ian
(5,696 Views)
Tula,
Unfortunately since LabVIEW doesn't own Mathworks, you cannot open MathWorks, Inc. MATLAB® program through LabVIEW MathScript nodes.  If I remember correctly there is legal tape holding that functionality back.
Pat B.
(5,679 Views)
Accepted by topic author TulaRen
Pat,
Actually, I found a workaround.
1. Within the MATLAB command window launched as MATLAB script node is loaded in LabVIEW, enter  "filebrowser", a "Curent Folder" window opens;
2. Within "Current Folder", select an existing m script,  the MATLAB main window opens. This MATLAB main window shares everything (e.g., workspace) with the one opened from MATLAB script node from LabVIEW, I can do almost any MATLAB stuff in this MATLAB main window. The only thing I cannot do is to "dock" the Command Window, but this is not as important.
Regards
Ian
(5,664 Views)
