Open MS Access from Labview- -Not a Connection to Access
I want to open an Access DB from LabVIEW. I don't want to open a connection, I just want a button on the front panel that opens a specific Access DB file. I have a program that is reporting out information from this database, but I want to be able to open the database, make a change or updates, and then close the database. Update the form and poof, everything is up to date. I don't want to manipulate data from my program.
There has to be a way to open a database, right? I have searched on this subject, and I can not find a method that has worked for me to open a database.
Any help is greatly appreciated!
Dave
Message 1 of 9
(5,883 Views)
Have a look at the Database Connectivity Toolkit
Regards, Jens
Kudos are welcome...
Message 2 of 9
(5,876 Views)
But that is used to open a connection to Access. Not what I want to be doing. I want to click on the button and open a specific database. Like if I went into explorer and double clicked on the file and it opened in Access.
Dave
Message 3 of 9
(5,870 Views)
I'm not sure if I really understand what you try to achieve. Do you want MS Access to start and then open the access db file? Or another Executable? In that case have a look at the System Exec VI
Regards, Jens
Message 4 of 9
(5,838 Views)
Message 5 of 9
(5,828 Views)
Your description is correct Jens. I have looked at the System Exec VI and I haven't gotten it to run or open the file I want it to open. I thought that should work too. Perhaps I need to just mess with it some more.
Dave
Message 6 of 9
(5,823 Views)
Accepted by DMerchen
Am I missing something?  This'll open a particular Access database in Access.
Jim
Message 7 of 9
(5,801 Views)
Thank you for the example. I have been trying to figure this out, but I didn't think it would be this simple. I shall give this a go. Thanks!!
Message 8 of 9
(5,783 Views)
Thanks! It was just too simple! I of course was overthinking it and trying too many different things. That space in between is critical as well!
Thanks again!
Dave
Message 9 of 9
(5,780 Views)
