Open an VI from an other VI
Do you know if it's possible to open an VI through an other VI front panel ?
Peter.
Labview 2010
Message 1 of 11
(3,472 Views)
What do you mean by opening other vi from Front panel?. Its possible and pretty simple you can use the vi reference and open it.
Message 2 of 11
(3,471 Views)
I have my main VI, and on it I want to have a command which can open and run automatically another VI .. Smiley Happy
Peter.
Labview 2010
Message 3 of 11
(3,468 Views)
You can use the Run VI method to do it. This is just an example for running a vi you may need to handle things depending upon the execution.
Good luck.
Message 4 of 11
(3,466 Views)
Yes you can by creating a sub VI and calling it in the main VI.
Message 5 of 11
(3,459 Views)
Where can I find  those fonctions ? I don't even know where they are Smiley Embarassed
Or maybe can you enclose your vi's example..
Thanks.
Regards
Peter.
Labview 2010
Message 6 of 11
(3,453 Views)
Try this VIs.
Best regards.
Thanks!
~drycsr~
Message 7 of 11
(3,449 Views)
Hi Drycsr,
Thanks for your help, but it seem that you have the newer version of Labview and I have the 2010 version so I can't open your VIs.
Can you make a print screen ? please
Peter.
Labview 2010
Message 8 of 11
(3,443 Views)
Accepted by Peter Saraiva
I saved it v2010 try again pls.
Thanks!
~drycsr~
Message 9 of 11
(3,439 Views)
Thank you a lot.
Peter.
Peter.
Labview 2010
Message 10 of 11
(3,427 Views)
