Open another front panel
I also deleted the cancel button and added a standard cancel button again and connected a connector pane
terminal to it. When I try to connect  it to the while loop condition, I get the following error message:
You have connected a loop test to an input of a subvi. Change the input to an output.
So my next question is, how do I change the input to an output?
Message 11 of 18
(1,968 Views)
Before you go any further, look at some tutorials to help you get started.
http://www.ni.com/gettingstarted/beginapplication.htm
Also, LV has an extensive list of examples under help.  Check them out.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 12 of 18
(1,968 Views)
Post your sub-vi or provide a VI snippet for it.  The cancel out is an indicator.  You need to provide a source for the boolean.  An indicator is a "sink."  See my previous post to this one.
Message 13 of 18
(1,965 Views)
Attached is my subvi
Message 14 of 18
(1,960 Views)
Here.  Just wire the Cancel? out to your conditional terminal.
Message 15 of 18
(1,951 Views)
Thanks Reese, but I can't open the example that you posted as I only have v8.2.
Please repost it as a lv v8.2 vi
thanks again
Message 16 of 18
(1,944 Views)
Accepted by Japper
Here you go.
Message 17 of 18
(1,941 Views)
thanks MoReese-
that did the trick!
Message 18 of 18
(1,930 Views)
