Open new VI Window loose control in main Vi
I have a main.vi that have a button that will open a new VI window.
I have no problem opening the new VI window, and passing the data to them.
The only problem is if I have the new VI opened, I cannot change any button state in my main.vi. Is this normal?
Only when I close the new VI window, I have access again to the main.vi.
(2,859 Views)
Can you zip up your VIs and attach here? I can see one place where you disable a control but I'd like to poke around a bit more.
(2,857 Views)
Accepted by PMSilva
Sounds like the vi you are opening is modal. You will need to change that to be able to use buttons in other windows.
Tim
GHSP
(2,852 Views)
Attached is the project.
Thank you
(2,764 Views)
Thank you. That solves my problem.
(2,729 Views)
