Open sub VI front panel in a tab--> Possible?
Well, the question is basically in the subject: Is it possible to call sub VI's and display their front panel in a tab. I do NOT wish to have the front panel in a new window when called.
(3,478 Views)
Accepted by _Faust
_Faust wrote:
Well, the question is basically in the subject:<...>
The answer is also basically in the picture:
You can find SubPanel element in the same palette as the Tab Control container. Place a SubPanel on the Tab Control and wire a reference of the VI whose front panel you want to display.
Message Edited by Giedrius.S on 02-13-2010 11:08 PM
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
(3,475 Views)
Brilliant thank you!
(3,463 Views)
