OpenCL for Labview is now Open Source
Howdy,
I wrote OpenCLV (OpenCL for Labview) about a year ago and have decided to make it an Opensource project availible on GitHub.  It contains all my C code to compile DLLs, all the Labview code, some pre-compiled x64 DLL code and a pre-built .vip project if you just want to download and install it.
https://github.com/amcelroy/OpenCLV.git
My email is in the GPL license header in the C code if you find any bugs or have any comments.
Austin
Message 1 of 20
(9,726 Views)
Hello Austin,
That's a really nice initiative. You can also upload your project on the NI Developer Community:
https://decibel.ni.com/content/community/zone
Camilo V.
Message 2 of 20
(9,667 Views)
Hey thanks,
I'll look into that as another avenue.
Austin
Message 3 of 20
(9,629 Views)
While I don't have use for something like this myself, the willingness to share open source code is appreciated.
One problem I would have with this, though, is the license. I'm far from an expert on licensing, but my understanding is that the GPL license is infectious - if you use a component which uses it directly in your code, you have to make your own code GPL as well to adhere with the license and the only way around that is to separate the GPL component into a separate, dynamically linked, component which would allow the end user to replace it if they want. See their FAQ here - http://www.gnu.org/licenses/gpl-faq.html#GPLInProprietarySystem
My understanding is that this is the reason that OpenG switched from GPL to BSD some years ago - BSD is more permissive and basically just requires you to place the copyright notice somewhere where the user can see it.
___________________
Try to take over the world!
Message 4 of 20
(9,588 Views)
The strict interpretation of GPL prohibits integrating a GPL component into a non GPL software even dynamically. That is why there is a LGPL. And that was indeed why OpenG changed from LGPL (not GPL!) to BSD several years ago. Many of the most influencing OpenG supporters felt that it was rather cumbersome to use it in non (L)GPL software. The most prominent product of this nowadays is VIPM.
The only exception to that change are the shared library components of the libraries that I wrote. I didn't feel that there was any bad influence from integrating them as LGPL into any sort of LabVIEW application, as they are fully dynamic anyways and by the nature of LGPL have no viral effect on the application that uses them.
Rolf Kalbermatter  My Blog
Message 5 of 20
(9,577 Views)
Hey guys,
Thanks for the feedback, I'll update the license to BSD and commit the changes this evening.
Austin
Message 6 of 20
(9,516 Views)
Hey folks,
Just updated from GPL to BSD 3-clause open source license.  Is this a good license for the community?
Austin
Message 7 of 20
(9,482 Views)
Awesome and cool! I didn't get as much extra performance as i thought from the examples (probably a cpu vs gpu issue), but being able to use the GPU as slave processor is awesome!
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 20
(9,448 Views)
Hey Yamaeda,
I have an AMD 7960 and compare it to an i5 @ 3.10 GHz, and see multi times improvement in the FFT and OCT processing examples.  There is an overhead to transfer the data to the card and back, so unless you are doing millions of floating point calcs it might not be worth it.
Austin
Message 9 of 20
(9,413 Views)
I'm comparing a AMD 8350 @ 4,5GHz CPU to an AMD 6970 GPU.
I was abit surprised too, but here's my result:
Qestit Systems
Message 10 of 20
(9,389 Views)
