OpenCL for Labview is now Open Source
That is a huge improvement!  The OpenCL FFT gives the option to run in single precision which Labview doesn't and is even better if you don't need the extra precision.
Message 11 of 20
(4,681 Views)
Lets just say that trying to force a bigger difference by changing to 2048 width didn't work out well. 🙂
(Graphics driver reset and VI hang)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 20
(4,680 Views)
Yeah, OpenCL on the GPU depends on how much memory the card can allocate.  If you scroll down on the device properties it will give you a heads up but it doesn't enforce it anywhere in the VIs.
Message 13 of 20
(4,675 Views)
/double post, sorry
Message 14 of 20
(4,674 Views)
New run gave 32ms and 44ms resp.
Very nice improvement, and i'm in no way accusing you, i just thought the massive parallellism would yield more. 🙂
This will be fun to play with. 😄
/Y
Qestit Systems
Message 15 of 20
(4,664 Views)
The more you can put into the OpenCL kernel to avoid data transfers between device and host and even global memory on the device, the better off you are.  Check the OpenCL cheatsheet if you are interesting in writing kernels, and there is a write-up in the manual.
Message 16 of 20
(4,657 Views)
Why did you use Write/Read buffer instead Map/Unmap? Map/Unmap will speed up transfer, because used DMA.
Can you correct you source for use Map/Unmap?
Message 17 of 20
(4,148 Views)
Hey, thanks for using OpenCL for Labview. I don't have the time to support this any more, but it is free on Github if you'd like to modify it. I would be happy to add you to the Github project so your changes can be merged into the main project.
Message 18 of 20
(4,114 Views)
OK. I changed to Map/Unmap. The speed up to 100x.
https://github.com/CyberRSR/OpenCLV
Message 19 of 20
(4,091 Views)
Thanks so much! Merged your changes into the main branch, glad to see some folks using this!
Message 20 of 20
(4,083 Views)
