OpenVPN Startup is killed by CRIO
I'm turning arround for few day now, and I don't now why my Crio 9067 kills my startupscript.
I'm using Labview 2015 and I define to start  openvpn at the startup with:
update-rc.d openvpn defaults
It's working nice. But seconds after my connection with the server is lost?!?
If I launch openvpn manually with:
openvpn --config ****.conf
it's not working in background, but my connection with the server is maintained.
It seems that the rtstartup.exe or another script is killing my connection.. someone can help me?
(I already format my CRIO.. 2 times)
(3,965 Views)
i found a thread https://forums.ni.com/t5/NI-Linux-Real-Time-Discussions/OpenVPN-not-working-out-of-the-box-on-9068-w...
which mentions, that using "openvpn --config" is not good.
please have a look, maybe your problem is described there
regards
ps: if you have the time i would be interested in a how-to on setting up openvpn
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,937 Views)
Thanks for the answer but I already did the test without the --config.
I created another sh script to start the svn (not the script that already comes with labview 2015) but I have the same behavior.
P.S => I was thinking about a little tutorial.. in the future, but now i just need to solve this problem for a project.
(3,927 Views)
Accepted by michael86
It was the order of the init script!!
(3,876 Views)
Hello I would like you to share how you configure openvpn in the crio (LinuxRT). I would be gratefull a lot!!!!
Roger Garcia, Certified LabVIEW Developer
HTML tutorial
There are two ways to tell somebody thanks: Kudos and Marked Solutions
(3,135 Views)
