Opening .txt file - Need another set of eyes
Hi folks - The attached file opens in Notepad and MS Excel as 9999 rows x 3 columns (X,Y,Z values, respectively).  I have tried different delimiters using 'Read From Spreadsheet File.vi' to bring in all the data but only successful bringing in the first column of 9999 values.  Can someone take a look at this and give me the trickto get it open using LabVIEW?  I expect it is something very simple but it is a Monday, isn't it?
Thanks in advance.
Don
Message 1 of 9
(4,080 Views)
The delimiter is a space (\s)
Message Edited by elset191 on 11-16-2009 11:31 AM
Tim Elsey
Certified LabVIEW Architect
Message 2 of 9
(4,063 Views)
This is all you should need to do...
-CAC
Message 3 of 9
(4,054 Views)
Accepted by DonRoth
Make sure you select '\' Codes Display.  otherwise it's actually \\s which is nothing. Additionally you could just use the space constant like the person above this post did.
Tim Elsey
Message 4 of 9
(4,038 Views)
...Bitten again by the syntax for 'Space Constant'!  Here is the easiest way:
Thanks for looking at this.  I knew it had to be simple - I was using \s for space delimiter and it will not work as mentioned above unless 'codes display' is selected (which I did overlook).
Message Edited by DonRoth on 11-16-2009 12:06 PM
Message 5 of 9
(4,033 Views)
Thanks for looking at this.  I knew it had to be simple - I was using \s for space delimiter and it will not work.
\s works.  See my post right before yours
Tim Elsey
Message 6 of 9
(4,027 Views)
I was in the middle of correcting the post when you replied....thanks again, Don
Message 7 of 9
(4,021 Views)
If you've ever been burned by this before, please kudo altenbach's Idea Exchange submission...
Indicate the display format of Strings
Message 8 of 9
(3,994 Views)
I have done so.  It is a good idea.  I normally work with binary files but it is remarkable how about every 2 years when a text file comes my way, I forget about this one....Don
Message 9 of 9
(3,980 Views)
