Operate PXIe-6570 with LabVIEW
I start to use PXIe-6570 in the NI PXIe-1083 chassis.
I saw and followed steps 1 to 5 in the NI guide (Getting Started with PXI Express Multifunction I/O Hardware and LabVIEW - NEW)
After installing NI software, we can see and self-test PXIe-6570 in MAX, as shown in the following Figure.
However, when I searched PXIe-6570 as a target in step 5 of the above guide, LabVIEW did not find the PXIe-6570, as shown in the following Figure.
I checked the NI forum but did not find a similar discussion.
Could you please advise me on the suggestion to work operate PXIe-6570 with LabVIEW?
Mirai1
Message 1 of 8
(3,046 Views)
Hi Mirai,
You don't need to add a "target" to your LabVIEW project, this step is used for Realtime hardware…
Instead you should use "NI-Digital" functions within your LabVIEW VI, according to the specs of that hardware!
Did you install the "NI-Digital" driver and do you see its functions in the functions palette?
Message 2 of 8
(3,026 Views)
Dear @GerdW,
Thank you very much for your advice.
1. Did you install the "NI-Digital" driver
-> NI-Digital Pattern Driver is installed as the following figures.
2. Do you see its functions in the functions palette
Do you mention the content in the following figure? [GETTING STARTED GUIDEPXIe-6570]
I did not see the NI-Digital Function palette in LabVIEW. Could you please advise me with a figure or guideline on where it should be?
Mirai
Message 3 of 8
(3,012 Views)
Accepted by Mirai1
Hi Mirai,
It should be visible here:
Look in the MeasurementIO palette (as shown) or in InstrumentIO…
Message 4 of 8
(3,006 Views)
Accepted by Mirai1
Mirai1
Foremost, 6570 is an instrument type on its own and NOT a Multifunction I/O HW and hence the article you cited is incorrect.
Once you install NI-Digital driver, you will see this palette in LV,
Santhosh
Soliton Technologies
Message 5 of 8
(2,988 Views)
Accepted by Mirai1
Dear @GerdW and @Santhosh,
Thank you very much for your guideline in detail with the picture.
I already found the NI-Digital palette in LabVIEW.
I would like to have additional related content, so it may be good to continue here.
I start to use an Example for PXIe-6570 in LabVIEW, as shown in the following figure.
Could you please advise me on some guidelines for using that examples or a process to work with PXIe-6570 in the correct way?
Mirai
Message 6 of 8
(2,950 Views)
Accepted by Mirai1
Since you're new to 657x, I would recommend taking up this course - https://www.ni.com/en-us/shop/services/education-services/customer-education-courses/device-testing-...
Santhosh
Message 7 of 8
(2,935 Views)
Dear @Santhosh,
Thank you very much for your good suggestion of a 657x course.
Mirai
Message 8 of 8
(2,914 Views)
