02-12-2006 02:31 PM - edited 02-12-2006 02:31 PM
If the existing files are part of a stand-alone application, select
Tools»Convert Build Script
to convert the application to a project. Refer..."
I did so and after a long period of time I recieved a message that indicates I canceled the operation. I did NOT.
I tried it again and got the same message.
I closed LV 8 adn re-opened and got another message indicates that LV had crashed last time is was open. It had crashed.
Any clue why LV does not want to let me convert a build script?
I can not post the code I am using due to IP issues. The application has over 500 VI's. It was last saved in LV 6.1.
Ben
Message Edited by Ben on 02-12-2006 02:33 PM
02-13-2006 09:58 AM
02-13-2006 10:05 AM
The VI mentioned in the error message was the same VI listed for both attempts.
The VI opened just fine in LV 8 when opened explicitly. The diagram was included.
Yes there was a password for that VI as was the case for many of the VI's in that application.
LV never asked me to enter a password.
Ben
02-13-2006 10:22 AM
Ben,
I know it's an unrelated question... but here goes> Why are you waiting until it is safe to post again??
I will probably find the answer in some other post somewhere between the twilight zone and some multidimentional reality... or... you could simply provide a simple answer.. 😉
02-13-2006 10:31 AM
Hi Ray,
You asked "Why are you waiting until it is safe to post again??"
I changed my signature after I read and thought about that legalistic blurb that recently was added to the bottom of every screen on the exchange.
The way I read it, half of my postings are affected by that verbage in one way or another. ( Besides, with less than 200 posting left to reach the "double Enthusiast" level, I can afford to slow down and let others have their chance.
BTW:
I am still looking for a solution to my orignal post!
Ben
02-13-2006 11:55 AM - edited 02-13-2006 11:55 AM
Whooooooaaaa!!!!!
What's this????? I never saw that until now... and here I am, providing examples left & right...
Yikes 😮 😮 😮
There is such a thing as being a double Enthusiast??? does it double your star count 😉
Message Edited by JoeLabView on 02-13-2006 12:59 PM
02-13-2006 01:11 PM
02-13-2006 01:24 PM
tst wrote;
02-13-2006 05:05 PM
02-13-2006 07:01 PM
Thanks JLS,
I recieved the following from Travis M.
This error or one extremely similar has been reported as an issue with
importing build scripts (NI Error Report ID: 3Q9EHGF2). It seems that an
error should be generated saying that one of your VIs is read only when it
needs to write the VI, but instead somewhere along the line its generating
error 43 (user cancel).
