Operation on waveform during acquisition
Hi
I make an acquisition of 6 channels by daqmx.
After a first acquisition where i obtain 6 means values, i need to make a continuous acquisition
with a waveform.
And i need at each loop to substract on each channel each mean value from data from waveform in order to have teh right measure.
Unfortunately, i don't succeed in......
Thanks a lot
(3,403 Views)
If you extract the Y array from each waveform, you can then subtract a scalar from each element. See the attachment.
(3,396 Views)
Thanks for your help
It seems to work but when drawing graph before and after substract, it seems that my graph "substract" seems to be noisy versus the original graph.
Is it normal?
(3,389 Views)
Perhaps your waveform was already noisy but you couldn't see it on the graph before you subtract the datas. It's probably due to
the automatic scaling.
Jean-Claude J
NI France
(3,362 Views)
OK
After analysis, it seems to be the same thing.
Thanks for your advice
(3,353 Views)
