PXI-8175 trigger bus
I am using the PXI-8175 embedded controller which has an external SMB trigger connection. Are there any example Labview code online (Ni.com) or within Labview 6.1 that shows me how to route signals in or out of the trigger connection? I am unsure how it operates, any additional information about its use would interest me, for e.g what is the relation of this trigger connection to the PXI trigger bus?
Thanks in advance.
Specs:
PXI-1002 chasis
Labview 6.1
(3,907 Views)
BiG-C,
As of 11/13/2002, the use of the SMB connector is a non-supported feature.
However, there is a BETA software written for LabVIEW that allows to route a signal to/from the PXI Trigger Lines from/to the SMB connector.
You can contact us directly at http://www.ni.com/ask and chose phone NI or e-mail if you are interested.
HOWEVER, NOTE THAT:
This software is not supported but can be given to you, but you need to be aware that it is still under development and you might run into issues that we might not be able to solve quickly. We would, of course, be very interested in your feedback if you decide to use it.
Cyril Bouton
Cyril Bouton
Active LabVIEW Developper
(3,909 Views)
hi can u plese send me the beta Vi? i need to check this out.
Thanx
mail id: arun.ananthkamath@angelantoni.it
(3,808 Views)
Hi Arun,
Please refer to the following knowledgebase online as there is additional information you should be aware of regarding the usage of this connector.
http://forums.ni.com/ni/board/message?board.id=270&message.id=1558&requireLogin=False
Best Regards,
Evan R.
http://www.ni.com/support
(3,791 Views)
Hi Evan
I have gone through the the link you had provided, and have understood the doc, i would still like to have it, atleast i want to know if i can use it.
Regards
Arun
(3,782 Views)
