Optimize way to manipulate Big text file ?
Ya, about the column width, it will always same for the same file.
 Here I attached the corrected file again. Thanks for the explanation here .. and just, anything !!
Message Edited by engwei on 03-18-2009 09:43 PM
Message 11 of 19
(2,077 Views)
If I was in your shoes I would have read one (or several lines), and shuffled the content. Then I would have written the content back to a new file. This can be done by a simple while loop since labview keeps the current file pos. Se picture. Then you reach end of file you will get error 4. Remember to add the end of line constant to the shuffled data because this constant is stripped from the "Read from text file output"
Message Edited by t06afre on 03-19-2009 01:49 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 19
(2,056 Views)
In essence, that was precisely what I had done in my quick and dirty VI. I had chosen to use Read from Binary File rather than reading lines so that I could get an array of bytes directly. This allowed me to easily pick off the columns I wanted. You could, of course, convert the string that is read by Read from Text File into an array using the Spreadsheet String to Array, but reading the line as an array eliminates this step.
I found that the limiting factor is file I/O. On a quiet system I was able to read 750K+ lines and extract the six column in about 30 seconds. Not too bad.
Message 13 of 19
(2,031 Views)
If the data is numeric only, I would definitely have chosen to write data in this format to the new shuffled file( 2d array). Not ASCII format
Message 14 of 19
(2,016 Views)
Erm.. think I will try to replace the "Read from file and String Spreadsheet to Array" to the Read file as shown above.
Thanks for your guys advices. 🙂
Message 15 of 19
(1,991 Views)
But I have found that, to convert Spreadsheet string to Array is only 0.032 seconds, and Array to Spreadsheet string less than 0.000X seconds.
For my experiment, there are 250 files to extract, each with 1k rows.
Each files will have to extract the columns of
(0,10,20,30,40,50) => 1st file
(1,11,21,31,41,51) => 2nd file
(2,12,22,32,42,52) => 3rd file
Extracting the column of 250 files will produce 250files x 3 column files = 750files.
The entire process took me 32 seconds.
Spreadsheet string to Array for 250 files = 250*0.032 = 8 seconds.
So, the other process took up 24 seconds.
And, if the VI "Read file" took no time to "read", probably the maximum time I can optimize is only 8 seconds, since the rest of the operation still involved "array" VI. ..
It that .. correct ?
Message 16 of 19
(1,970 Views)
Could you post an example. Hard to say without seeing some code
Message 17 of 19
(1,965 Views)
Here I paste it . .
Message Edited by engwei on 03-20-2009 05:24 AM
Message 18 of 19
(1,963 Views)
You seem to have changed the premise of the question. Initially you said you were dealing with one file with 840K rows. Now you say you're dealing with 250 files, each with 1K rows. That's a big difference.
It seems that in your inner loop you are extracting columns based on some sort of input string, though it's not clear since we can't see the rest of the code. It would be easier if you actually uploaded the VI. If my assumption is correct, then my guess is that you can replace the while-loop with a for-loop in this case.
Message 19 of 19
(1,938 Views)
