Out of memory on application build - what to do ?
We are consistently failing to get a LV 8.2.1 application to build at the last step - we are using GOOP with about 30 different classes and are attempting to compile on an XP machine with 1.5GB. This is the explicit error we get:
Error 2 occurred at Invoke Node in ABAPI Dist Build App from LLB.vi->ABAPI Build Application.vi->EBEP_Invoke_Build_Engine.vi->EBUIP_Build_Invoke.vi->EBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Memory is full.
NI-488:  No Listeners on the GPIB.
Method Name: Build:Application
Anyone have any suggestions ?
(2,663 Views)
Before you build your application does it run without any unexpected behavior?
There is another forum thread with the same problem that may be of use to you. Follow the steps at the bottom of that post and post back on this one if you still have the issue.
Good Luck!
Tom | NIUK
(2,644 Views)
