Output Signal from PXIe-7846R
While working on my project- I need to generate digital signals with regulated duration and period between pulses. I tried to generate those signals and looked up using an oscilloscope but no signals were outputted. I simplified connection and program to investigate the issue. Now the problem is as you can see on the screen below. DIO0 (on pin 36 of NI-7846R) is connected directly to DIO1 (on pin 37). As you can see, no positive signal is received on DIO1 input. How exactly should I set DIO0 to be able to set digital Output to Positive? Is there any example of outputing signals using DIO on PXI ?
(1,959 Views)
Accepted by Mastrz
Are we speaking about PWM?
If yes there are lot of recourses and examples like this one:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015CPCSA2&l=en-US
Have you followed any example or guidance?
__________________________________________
The best way to thank, is to give KUDOS
(1,705 Views)
