Output frequency is different then the set value
Thanks alot for your reply. I saw the data rate before but douldnt really get it at that time. When I set the frequency and sampling rate to be 1652 it was exact. Thanks for explaining. Appreciated.
Message 11 of 14
(1,295 Views)
Message 12 of 14
(1,295 Views)
I understood it now. Thanks alot for explaining. Appreciated!
Message 13 of 14
(1,292 Views)
Tip on the forums.  You only need to reply once.  It looks like you were trying to reply to each individual message.  The messages are all posted sequentially in the thread.  There is no real association with your message and the specific one you are replying to.  If the message gets long enough that it is unclear that your reply it so a specific message further back in the thread, then use the QUOTE button to put the referenced message (or relevant portion of it) into your message.
Message 14 of 14
(1,275 Views)
