Output numbers in Dollar format $5,400.00. Can Labview do this?
(2,916 Views)
You can't have a numerical indicator with other format than numerical, but you can use strings for that, just wiring the number to Format into string function and set the format you want.
Hope this helps
(2,916 Views)
-Right click on your numeric indicator
-Select Visible Items - Unit Label
-Set $ as unit label
(2,916 Views)
