Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Output numbers in Dollar format $5,400.00. Can Labview do this?
erw
Member
05-25-2001
04:54 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
0
Kudos
Message
1
of 3
(2,915 Views)
Reply
Re: Output numbers in Dollar format $5,400.00. Can Labview do this?
Gorka Larrea
Active Participant
05-26-2001
02:22 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can't have a numerical indicator with other format than numerical, but you can use strings for that, just wiring the number to Format into string function and set the format you want.
Hope this helps
0
Kudos
Message
2
of 3
(2,915 Views)
Reply
Alberto
Active Participant
05-28-2001
02:57 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
-Right click on your numeric indicator
-Select Visible Items - Unit Label
-Set $ as unit label
0
Kudos
Message
3
of 3
(2,915 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
