Overhead of using Wfm Graph as subVI output terminal?
--My core question:
If the Front Panel remains closed, is there any difference between a Wfm Graph and a Wfm Indicator as an output terminal?
--Question in context:
I have a non-reentrant subVI that will run in my program and output a Waveform.  Occasionally, I will want to open up this subVI's Front Panel, and tweak its internal parameters while viewing its output on a Wfm Graph.
The minimal solution would seem to make the Wfm Graph of the subVI Panel double as the Output Terminal, as opposed to outputting through a Wfm Indicator.  But would that increase the resources used during the subVI's normal operation?
Thanks in advance, and have a great day.
--Brad
(3,190 Views)
Accepted by BradNC
There should be no overhead. The graph would only update if the front panel is open. Most of the time, the front panels of subVIs aren't even in memory.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,189 Views)
Thanks a bunch Mike.  That's about how I had it figured, but well...sometimes I figure wrong.
Thanks again, and have a great holidays.
--Brad
(3,137 Views)
