Overlay midpoint
I am having an image that goes through several stages. At one stage an overlay is created on the image. But this image with overlay is not saved anywhere. My question now is: Is there a way to find the coordinates of the centroid (x) in the image with overlay ?Since I am not saving the file i cannot use IMAQ Read image & vision info vi.( correct me if i am wrong)
Any better ideas to deal with it?
Nghtcwrlr
(3,938 Views)
You may also want to post the same query to a much relevant board, that's 'Machine Vision'.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,918 Views)
Do you want the centroid of the overlay or the centroid of the image?
If the centroid of the image why not just use the Image Size then work it out from the x,y coordinates.
If the centroid of the overlay, how are you creating the overlay? If you are creating it from an ROI, you could work it out from the global rectangle of the ROI.
(3,909 Views)
It's been a bit since I've worked in Vision but I believe the problem is the overlay is a type of meta data on top of the image, and when you go to save it just saves the image not the ROI.  If this is the case you need to use these two functions to merge the ROI and the image so the save will include it.
https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/imaq_overlay_roi.html
https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/imaq_merge_overlay.ht...
(3,889 Views)
@ Phil_ : I want to have the centroid of the overlay. I looked trying to find how  the overlay is created. All of the overlay creation steps are done inside a dll. I was not able to find any ROI in it. And i am not  supposed to reveal the dll due to privacy problms.
@Hooovahh: I do not want to save the image with overlay. I just need to use the image with overlay to find the centroid.
Nghtcwrlr
(3,863 Views)
So this isn't an Imaq overlay, this is an overlay drawn with your own dll?
I assume that means that your original image will be greyscale, and your image with overlay will be RGB?
If the overlay is always the same colour maybe you can isolate the overlay using the colour information somehow and work out its centroid from there?
(3,859 Views)
