Overlay of text on 16-bit image
I found it, Image Mask...
Sorry
Message 11 of 14
(1,336 Views)
A late comment on this thread (because I am involved in this one: http://forums.ni.com/ni/board/message?board.id=200&message.id=24199&jump=true😞
It does not make much sense to build a destructive overlay on a 16 bit image. The overlay hides parts of the original image. Hence it is only of limited use for further processing. I think the main reason for the overlay are documentary purposes. RGB is completely sufficient if you print or view such a documentary image. There is perhaps an exception for medical images which will be displayed on 12 bit displaying monitors.
Message 12 of 14
(1,312 Views)
Thank you all for this discussion.
I tried Adam_H's solution, but I am dealing with U16 images. If I typecast from RGB to U16, I get a black image with the text. What steps do I need to add?
Message 13 of 14
(991 Views)
*did some digging*
Have you found a valid solution? I'm also troubled by the U16-problem. I use 2 cameras with 10 and 12 bit. The cast from U16 to RGB32 seems to be broken (and does not work as single function either).
Thanks!
Message 14 of 14
(773 Views)
