Overlay runtime data on top of excel data
Hi all,
I have data from Excel that I would like to plot on a graph in LabView, then as the program is collecting data, I would like to overlay the current data on top of the Excel data as a visual to make sure that the test is running well.
Does anyone know where an example of such a vi might be?  Or maybe you can give me some hints on how to do this?
Thanks for any help,
Matt
(3,281 Views)
oh I'm sorry I forgot to mention I have Labview 2009
(3,279 Views)
Basically, you would first load your data into LabVIEW and have that be your initial array. You would then build an array within a loop that reads your runtime data. The attached example shows the general concept.
-Zach
(3,246 Views)
Zach,
thanks so much for getting back to me.  How would you manipulate this code so that if I were to hit a stop button that it would stop execution of the for loop?
Thanks again,
Matt
(3,237 Views)
Accepted by Matt-UHart
If I did not have a maximum number of iterations, I would use a while loop instead. Otherwise, if there is a maximum number of iterations, a stop terminal can be added to a for loop by right clicking the loop border and the selecting the option for a conditional terminal.
-Zach
(3,229 Views)
Great thank you this works perfectly.
(3,219 Views)
