Override On/Off valve in while loop
Accepted by ucbeoha
Smiley Very Happypls close this thread marking as solution accepted.Smiley Wink
Message 31 of 38
(1,871 Views)
Hello, and good day
I have to make a test on two solinoid valves on/off , when the first on the second off and vice versa becouse they instull on one hydrualic line and I saw this LabView that you explain . is it posible to use it or I have to re buld it again?
Thank in  advance
Message 32 of 38
(1,818 Views)
On time and Off time is 0.06 for each means to say 15 times per second
Message 33 of 38
(1,815 Views)
Hello deadmaster,
This is old post so if you start a new thread with full details of your application and problem you would be more likely to get help from the community.
Many thanks,
Mahdieh G
Applications Engineer
National Instruments UK&Ireland
Message 34 of 38
(1,799 Views)
 Dear Mahdieh G,
I have to make a test on two solenoid valves connecting on one hydraulic line on/off , when the first (on) the second is (off) and vice versa.  (On time) and (Off time) is 0.06 for each means to say 15 times (on/off) per second because they install on one hydraulic line as a mention and I saw this LabView  file that you explain . Is it possible to use it or I have to re build it again?
Message 35 of 38
(1,791 Views)
This post has already been marked as "resolved with a solution". Please can you start a new post/thread and fully explain your problem so that the community can help you. Please also include details such as which version of LabVIEW you are using and what hardware you will be connecting to.
Generally speaking, LabVIEW can be used as a control software that switches your digital lines to control your valves.
Mahdieh G
Message 36 of 38
(1,772 Views)
The version of the LabVIEW that i used is :"National Instruments LabVIEW 2009 (32-bit)"
The hardware that I need to connect is DAQ (digital input, digital output , and analog input)
Message 37 of 38
(1,757 Views)
I have to make switching on two solenoid valves  on/off  15 times per second then 75 times per 5 second , when the first (on) the second is (off) and vice versa.
Hope to fine the advice
Thank you in advance
Message 38 of 38
(1,754 Views)
