Overwriting a portion of a text file without reading the entire file
@SolPS wrote:
Hi Altenbach,
Thanks for your reply. The file will be accumulating data over time and get very large. That was why I wanted to see if I could avoid having to read the entire file.
If you're just adding data, why read the file at all?
Just open the file (or keep an open reference), move the position to the end (if you just opened the file), write data....
Message 11 of 14
(222 Views)
wiebe@CARYA wrote:
@SolPS wrote:
Hi Altenbach,
My understanding of the problem was that the file is ultimately very large, but they want to change the header (i.e. the beginning of the file) at any time. Of course it does sound a bit weird why that would be needed. 😮
Message 12 of 14
(207 Views)
I need to edit parts of the header in the data log file each time a new data set is appended to the existing file. The new data addition can occur over a period of several days during which time, the amount of data in the file would have become considerably large.
Message 13 of 14
(203 Views)
OK, but that's covered now, right?
☑️ Reading (just) the header is no problem...
☑️ Modifying the header is no problem (as long as the size doesn't grow)
☑️ Adding data isn't a problem.
Message 14 of 14
(189 Views)
